MF40INdustrial
I have attached a photo of the control valve for an IH model 1000 one arm loader that was built with a model 400 IH blade only. This valve raises and lowers the main arm with a single line and control valve. One direction raises and the other lowers.
Does anyone have a photo of the valve from a 1000 loader that has the hydraulic controlled bucket also?
Can the two blocked holes on this valve be used for two way external hydraulic connections? If this valve is removed, is another cover plate needed to replace it ?
THanks
140 with factory 1000 one arm blade.
THanks
