Trying to find out what tractor I have_trouble with hydraul
Anonymous-0
I have an Int"l tractor, but don"t know the model #_ it has the number I2500DBL on it. It is a diesel, and I think it may be a 574, it has been painted red, but there is yellow paint underneath. I am having trouble with the hydraulic arms. When I try to lift an implement, the arms chatter. I tried playing with the draft controls. When I shut the tractor off, the implement does not drop all the way to the ground.
It is an industrial model of the 574, It has a straight axle. I have a 2400 and it is an industrial model of the 454.Is it full of fluid? Have you changed the filter?....James
If it is not a mechanical fault it sounds like air or water in the system.
If there are obvious leaks then fix them. drain the filter element for water. After that if no leaks cycle it several times with no load and see if it gets better.
