One row cultivator
James Williams
I am rasing a garden this year and I bought a one row cultiavator from tractor supply,but I think the Tynes are spaced to far apart.can some one measure a cultivator and tell me the corect spacing between each tyne or plow point
jimmy
Jimmy, It depends on what you are cultivating.
If you set it for your crop narrow to start if you run through them later you may want to sprade it out after crop has grown some.
Also the shape of the shoes straight shoes
narrower and cutter shoes or hillers wider.
Hope this helps. Oldiron29
