Farmall Cub which decal kit?
With the serial # you provided, that would make it a 1953.Not sure what is meant "early" or" late" Cub other than the very early Cubs used a decal with a circle and the word Cub was inside the circle. You are better off telling whoever you`re buying decals from that you want decals for a `53 Cub. Good luck,Mark
A lot of places will give you a couple choices and let you guess which one might have most of the right decals. If you follow the pointer to TM you will find there were a dozen or more versions and they will give you a straight answer on which set to use.
Great place to deal with too.
