The wd9 I got about 2 months ago runs great on gas but I can't get it to run on the diesel side when I got the tractor I drained all the fluids and changed the filters because it sat for several years the pump presure gauge is showing presure the only bleader that I can get any fuel out of when running is the one on the fillter closest to the pump and it will spray real well but nothing out of the rest of them this is my first gas start diesel please help
Stewart
To bleed the system you need a full tank of fuel. With the engine off bleed any air out of the fuel bowl and the rearmost filter. Start the engine, bleed the front filter. Then open the diesel throttle a bit and crack the small bleed screw on the back side of each injector until you have solid fuel coming out. Be very careful doing the latter as you are dealing with high pressure fuel and you don't want to inject it under your skin. There is a small hole the fuel will come out of, take note of this before you start. Good luck, Sam
any of my 9 and 600/650 series tractors all i have done to bleed the system is get fuel to one of the filters first and then started it on gas and let it run. fuel should come to your other filter fairly quickly. there is a bleeder on the pump that will have to be opened next. once fuel is there i crack injector lines. fuel spray there then i switch it over to diesel. always run fine for me. no need for a full tank of fuel to do so either.
