After I remove the lift all pump from the farmall H what maintenence procedures should I do to make sure it is up to par. The pump works ok now and doesn't seem to leak but after using it awhile and the oil gets warmed up it does seem like it is a bit weak. Is there something I can do to improve its perfomance beings I am going to have it out of the tractor?
Also I know I read on this forum about removing the pump with ready rod to make it easier. Can someone refresh my memory?
