Chris NW Ind
Got this problem that is baffling me. The power steering on my 450 refuses to work unless I operate any of the 3 valves. Then it is perfect. It seems that by operating a valve, I'm dead-heading the system and building-up full pressure which is allowing the PS to function.
I've had most of the regulator/priority valve apart on the tractor. Nothing is stuck, all o-rings are new. The only I didn't check yet, and will tommorrow, is the PS safety valve and spring.
Any thoughts?
Thanks, Chris B.
Any thoughts?
Thanks, Chris B.
