F12 with factory Generator?
it mounts on a special lower block elbow. has brackets right on it. have seen original ones and aftermarket. sorry, no photo. pg
Well I dont have pictures of the original mount that was cast as part of the elbow, but here is the on I made for my F-12 when I put lights on it a couple years ago.
Just made it out of flat steel and angle iron. Little and grinding, drill a couple holes, and there it is. Then the top is held in place by a bracket that mounts on the center bolt holding the water outlet above the fan.
-Jordan
We have one here at Alderson Tractor i'll try to post a picture of one. Give us a call if you need one. 641-624-2275
