new 450 hyd pump
756puller
i replaced the hyd pump on my 450 to get it to steer better, i had it runnung just perfect then it would die all of a sudden, i took the distributer off and it looks like the tang just wasnt quite in the groove, i shimmed the tang so it was tighter and it hasnt missed a beat since, is there a hyd pump that works better in the drive than the a and i pump i put on?
Your fix seems to be a good one. If it is operational, I would do two things. Let the supplier know the issue you had, and enjoy the tractor running well. Replacement new pumps can be hard to find, and expensive. JimN
its not hard to find, i just had to get the power steering working since it is a loader tractor, it wasnt to expensive i thing 550 brand new thru a and i
