FAST HITCH 560D
There was an article online at another site a few years ago describing the ordeal a person went through troubleshooting a similar problem with his fast hitch. It was pretty much, "take it all apart, figure out what's wrong, and fix it..."
Is the draft control linkage from lift cylinder to hitch control valve intact? If that linkage is broken or unhooked, it can affect the hitch as you describe.
I had the same problem last year. Take the lower sheetmetal in front of shifter off. Behind it is
covers to the hydrulic control valves. take the
cover off of the to the left and see if the clip
has come off and the pin fell out. I spent 3 days
looking at everything else before i found the
simple fix.
Remove the sheetmetal in front of the shifter.
the depth control valve linkage is behind the
cover to the left. See if the clip came off and
the pin feel out.I worked on one for 3 days
looking at everything else before I found the
simple fix.
