200 serial #
rollinred
New User
I`m trying to figure out the#`s on my 200. I`ve got 3866J on the clutch housing and 7275 stamped under # 1 spark plug next to where C123 is cast, are these the correct #`s to use to identify the tractor? thanks Richard
Richard: Those number are very likely correct, just the right amount of spread between chassis and engine serial numbers. 3866 is chassis serial number, J stands for Rockford clutch. Since 100 and 200 tractors each had their own sequence of chassis serial numbers each starting at 501, the C-123 engines in both shared a common sequence of seral numbers. In 100 and 200 engine number will be aprox twice the chassis number.
Richard: If your ordering engine piston and sleeve kit, use the block part number 354898 R1 or R2. There are five 3-1/8" bore kits out there and only one of them fit your block.
If he advises you have to measure the sleeve holes, suggest he study his parts business, and ask to speak with someone who knows.
