Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Farmall F-20 Spark Plugs
Andy Motteberg
12-12-2008 22:24:32
Hi all, I'm going to buy new plugs for my '38 F-20. I need to know the part number for the Champion plug that fits the F-20.
Thanks,
Andy
Tom Fleming
12-13-2008 17:04:14
 Re: Farmall F-20 Spark Plugs in reply to Andy Motteberg, 12-12-2008 22:24:32
Andy, go with the W-18's unless you are burning a bit of oil, then go with the W-20's. The hotter W-20 will burn the electrode faster if used heavily under load, which will change the gap, and eventually fail. However, if you have leaky valve guides, or worn rings, they are the ticket for good ignition.
Quite frankly, I have used both Autolite and Champion without any noticable difference. But to be clear, the only work my old girls get is an occasional antique tractor pull, or pulling logs out of the woods.
However, as with any product, then can be a bad batch, or design flaws that are corrected in later production runs.
I say run what works for you.......
Andy Motteberg
12-13-2008 18:03:35
 Re: Farmall F-20 Spark Plugs in reply to Tom Fleming, 12-13-2008 17:04:14
Thank you Tom.
Andy
Old-F20
12-13-2008 12:18:44
 Re: Farmall F-20 Spark Plugs in reply to charles todd, 12-12-2008 22:24:32
rustred said: (quoted from post at 11:17:34 12/13/08) andy asked for a plug # and nobody gave it yet. i believe its W14 thats the common one. you can go up or down in heat ranges.they must be trying to put champion out of business, by bashing them.it dont matter what plug you use you can have a failure.give some of your reasons guys.
they will eventually put themselves out of business by continuing to make shi*produstc. I have used them in the past so dont think im on the aotulite bandwagon without any prior experience :!:
J.J. from Afton
12-13-2008 10:34:52
Like the others said youd be better off to go with Autolite 3077s. Ive got nothing against champion, we use them in our other gas tractor and cars and trucks. But like the others I have found they just do not work as well with my F-12. I went to the 3077s on the reccomendation of the Cowman, and it runs (and starts) better than before. Just my experience.
-Jordan
Andy Motteberg
12-13-2008 16:44:16
 Re: Farmall F-20 Spark Plugs in reply to J.J. from Afton, 12-13-2008 10:34:52
Thanks, I'll put in the W-18 or W-20.
rustred
12-13-2008 10:17:34
Andy Motteberg
12-13-2008 16:43:20
 Re: Farmall F-20 Spark Plugs in reply to rustred, 12-13-2008 10:17:34
Thanks, My F-20 has 4 new Autolite 3076 plugs 2 have no fire. I prefer Champions.
Thanks,
Andy
SproutW
12-13-2008 11:50:58
W-18 and W-20 is what I've used in the past for Champion plugs.
Andy Motteberg
12-13-2008 16:41:36
 Re: Farmall F-20 Spark Plugs in reply to SproutW, 12-13-2008 11:50:58
Thanks, that's what I will use.
Andy
Old-F20
12-13-2008 07:40:58
CHAMPION SUX!!!!!!!!!!!!!!!!!!!!
go with either autlite 3076's or 3077's, you wont be dissappointed!!!
Andy Motteberg
12-13-2008 16:41:05
 Re: Farmall F-20 Spark Plugs in reply to Old-F20, 12-13-2008 07:40:58
My F-20 currently has 4 BRAND NEW Autolite 3076's in it and they are JUNK. They have no fire at all. I have used Autolites in cars, trucks, vans, mowers, tractors, small engine and have had a lot of problems. I use Champion and NEVER had any problems. I'll put in the Champion W-18 or W-20. Any spark plug can have problems, but the Autolites have been the most trouble for me.
Thanks,
Andy
SproutW
12-13-2008 06:31:05
Andy I know you like the Champion plugs but I've hand nothing but troubles with them in my F-20's. I switched over to the Autolight 3076 and have had no problems. Plus they are half the price of the Champions.
F-Dean
12-13-2008 06:17:06
I have had better performance from my F Series tractors (and my W-30) with Autolite #3077.
