340 engine serial
stockag17
New User
Im tring to find my engine serial number so i can set my valve tappet scince theres 2 diffrent setting depending on when it was built. Its a C-135 and the tractor serial is 2295, there is also an S after it that i dont know what it stands for. I have look were the owners manual says it would be but have had no luck.
(quoted from post at 12:46:41 11/29/08) Engine serial is stamped on a pad under the #1 spark plug.
right under the spark plug thers a square block the stick out that has been partly machined is that where the stamp is suppose to be?
