one way clutch 460
LloydE
Is there any way to test the one way clutch out of the ta on a 460 when you have the unit out and disassembled.
Thanks
You should measure and do a visual inspection. The bottom end of the carrier should measure 2.858 to 2.875. There should be no flat spots in the roller area of the ramp and should be no scars or chips in the bottom end of the carrier. To see if it's working ok the ramp should turn clockwise and lock counter clockwise. Hope this helps. Good luck
Kevin
