Anonymous-0
This project fixing leaks and a broken oiler gear in our tractor just keeps getting bigger and bigger..
Decided to replace the rear axle oil seals while we are into it this far, and as close as I could measure with my digital calipers, it is not a standard size shaft for the seals.
Did International like to use odd-ball sized seals that you can only buy from them? Does somebody have the National or CR interchange number?
Thanks.
Thanks.
