Absent Minded Farmer
- Location
- Gehl Country, Wis.
Had no problem what-so-ever uo until 3 days ago. Then, nuthin'! Ka-put!! No charge! Before I tear into the electrical system again, I'd like a little input. Here's the background: I rewired the H about 4 years ago. Changed out the old wiring for a brand new harness setup. Took the generator apart & gave it a good cleaning. Voltage regulator looked new so I left well enough alone. Fresh wires for the lights. A new push button for the starter. A double-ought-gage "pipeline" going to the push button from the batt & one going out to the starter. A new starter was put on last year. Fresh battery, too. I think I've plumb run out of things to replace. The only thing that didn't get replaced were the lightbulbs & the lights/gen. switch. Might that switch be my gremlin? Where else should I look? Thanks - Mike
