UNIQUE C FARMALL
Anonymous-0
RAN ACROSS AN UNIQUE C FARMALL. IT HAS ONE AXLE THAT IS APPROXIMATELY 3' LONG WHILE ON THE OTHER SIDE THE AXLE IS ABOUT 15-18" LONG. ON THE SERIAL TAG ALL THAT IS THERE IS THE WORD (MODIFIED) STAMPED WHERE THE C WOULD BE. TRACTOR DOES HAVE LIVE POWER SO WAS THINKING IT MIGHT BE A SUPER C. I GUESS IF SOMEBODY WOULD SHED A LITTLE INSIGHT I WOULD APPRECIATE IT, THANKS IN ADVANCE.
Someone either cut off one side or replaced the other with the long axle that was an option. If you thinks that one is odd should have seen the B with the AV tires and wheels and then a AV wide front with the standard 15in tires on the front. Painted White with DEMONSTRATER decal on gas tank. Said it was a 44 model but the engine was cast in 40 sure was fooling tons of people as they sure took lots of pics.
C and Super C have live hydraulics. PTO is transmission driven, and although nothing is impossible to change, that would be pretty close. Axles are as Gene said. Max standard tread on the C was 80", 100" was optional.
That long axle was for a mounted corn picker (sinle row) that was made for the C. I don"t remember the number of it. I have only ever seen two of them
