craigreavley
<a href="http://s34.photobucket.com/albums/d111/craigreavley/?action=view¤t=100_0787.jpg" target="_blank">
</a>
I have a farmall 340 that has a stuck engine, and I need an overhaul kit. The tractor stuck from sitting several years with a bad head gasket. The crankshaft was still in oil, and appears to be alright. Looking from below up with the oil pan off it looks like cylinders 2 and 3 are rusty, under the pistons, on the sleeve. I am considering the inframe rebuild kit from this site, and it lists TISCO as the brand. Is this a decent brand? All of this is assuming that the lower end bearings are ok. The following is the kit I am considering. Anyone have any experience with this rebuild kit
Basic IN-FRAME Engine Kit - Made by TISCO. In Frame Engine Kit, For Models: 330 & 340 up to SN 100500. (C135 CID 4-cyl Gas, 3 14 inch standard bore) For tractors with stepped head pistons).Kit contains complete sleeve and piston kit with rings, pins and retainers, valve grind gasket set and pan gasket. (Part No: BIFH1165) $381.75
