Fan on Farmall C
Celeste
New User
Does the fan on a C have bearings? If so how do I get to them or does the whole fan assembly need to be replaces?
Ok I now know it has no bearings.
The fan quit. After dis assembly I found what appears to be a grease fitting. hard grease inside. Can it be cleaned and replaced or total replacement necessary?
I would try cleaning and greasing before buying a new one. Also make sure the belt didn't stretch when it quit. However there is adjustment for that. Henry
It should be filled with oil. Grease won't do any good in there. Read the lube instructions in the Owner's Manual.
