544 Hiccups
Piston seal is leaking on the three point and to fix ya have to take the whole thing off to get to it .Then check the bore for any nick scrapes , i usualy run a cylinder hone up and down the bore using a 220 stone to clean them up then install the new seal some are a big O/Ring and some are like a piston ring.
my dads 404 did that when he got it. he replaced almost everything in the back but the cycender, in cluding the "drop-pop-it valve" (?) and after spending a few huindred dollars, it turned out to be and 89 cent seal. the moral i suppost is start cheap and work your way up.
