Anonymous-0
Hi folks,
I've got a '64 German made farmall w/ a 3 cyl diesel motor. It runs fine, but the coolant looks black. When you put your finger in the radiator it comes back with some black stuff that looks like suite, but the coolant under the film is normal looking. The cap has a little foam on it, but I just put that down to it being used so little and not really warmed up most of the time. There is no discoloration, foam or water in the crankcase either and the radiator doesn't bubble/build up pressure like a headgasket would.
Does this problem sound familiar to anyone?
Thanks, Dave
Thanks, Dave
