TractorLinks.com
Show Parts for Model:
How heavy are Farmall A, 130, 140 rear wheel weights?
Randy Dragoo
06-23-2008 08:53:14
Any one know what these offset farmall rear wheel weight actually weigh per side? I want to make sure I'm getting the right weights and not those for a cub.
Retcol
06-23-2008 18:12:52
 Re: How heavy are Farmall A, 130, 140 rear wheel weights? in reply to Randy Dragoo, 06-23-2008 08:53:14
I would think the weights for a Farmall A would weigh more since they are bigger than the weights for a Cub. I just weighed one of my Cub weights and it was just under 150 pounds.
M L K
06-29-2008 07:18:49
 Can you answer a ? about my 1969 Farmall 140? in reply to Retcol, 06-23-2008 18:12:52
I was wanting to know if I could pull a finish mower behind my tractor since it has the offset PTO (to the left). I had an after-market 3 pt. hitch attached a few years ago. If I can't, is there any modification I can make to the tractor so I can pull a mower? I have the belly mower to it, but I'm wanting a finish mower hooked up. The belly mower has issues. Thanks if you can help me out here.
NawlensGator
06-24-2008 09:27:51
 Re: How heavy are Farmall A, 130, 140 rear wheel weights? in reply to Retcol, 06-23-2008 18:12:52
This will surprise you. The super A / 140 rear weights weigh about 145 lbs, while the cub weights are about 150 lbs.
Daniel H.
06-23-2008 14:04:39
The weights you want will have the number 6701DA cast into them.
NawlensGator
06-23-2008 09:40:16
The center hole is smaller on the cub weights.
I have a set of each, but can't remember the exact inside diameter. I think the weight is about the same.
Andrew Z
06-23-2008 08:59:45
They are about 145 or so. THe cubs are like 130. you can tell the diffrence though just in shape the cubs have a much "sharper" inner compared to the A's B's 100 etc. (just look on ebay for pics there always sets for sale)
Andrew
