300 oil supplys
PeteEllis
just got a 300 utility. Drained about 2 gal of oil from the TA section in front of the clutch. what is type oil and amount to replace. is this an isolated oil supply Have not got the owners book yet.
Trans, diff & front part are all one res. two check plugs, one on diff. housing and one on clutch housing,same level. Three drain plugs, one bottom diff. one very front diff housing amd one bottom of clutch housing. Jim
