Farmall M Govenor Problem
Jim R
I recently purchased a 1950 Farmall M. I don"t yet have a manual for it. It runs great but the engine sounds like it is only running at about 60% of full RPM with the throttle wide open. Can any of you Farmall guys out there talk me through how to adjust the govenor, or how to get full RPM out of it? thanks for any response!
Get the I&T manual for it it will show you how to adjust the gov. It easy it involves turinging out a bolt inside the gov. and or adjusting the rod under trhe hood if you cant achive the RPMS though the gov. adjustment alone.
Anderw
Have had to replace the spring in the governor on several old farmalls have even seen them break once or twice
