F-14 brake cover removal
Anonymous-0
My right brake is leaking some oil and it needs adjusting and I also notice a rusted out hole in the bottom. I removed the 2 bolts holding the cover over the brake drum but can't get the cover off. Is there a trick to getting it off without destroying it. I will see if I can repair the hole or if someone has a good undented cover I would be interested in buying it. I am also looking for a good seat with working spring - not that it helps much when your driving it. Thanks, Hank 785-748-0061
Those covers are always a little tough to get off, but if you can carefully pry on it, it should come off. If yours just has a small rust hole, you should keep it, it is almost impossible to find F-12/F-14 brake covers that are not rusted out. Steiner Tractor Parts sells brand new brake covers.
