front main seal
Idaho Ron
I need to do two. My 41 A is leaking and now my 53 Super C is leaking a little. I know I going to have to strip the whole front end's off. How do I support the super C when the front wheel is off? Do you guys use some kind of stand? Thanks Ron
Be sure to take close look at those hubs for worn grooves. Speedi sleeves are available to cover that area. Be careful. Hal
The rear of the tractor from the back of the engine weighs more than the front. Jack up the front and place solid wood, or blocking under the belhousing (torque tube) Place it so no tin covers get bent. jimN
