450 Farmall- oil leak
Anonymous-0
Tractor is leaking oil just below the distibutor cap. Looks like some one has put a cork seal and a peice of sheet metal over the opening. Just wandering what should go there,that is correct? This tractor i s equiped with power steering.
Thanks for any help!!
If the leak is coming out of the cap, the Hyd. Pump needs a seal. If it covering a factgory hole, it might be the draft tube location, with a butchered up replacement. caseih.com search for parts will get you to a nice diagram. JimN
