Anonymous-0
Yesterday I was mowing grass with my International 185 Lowboy. When I shut it off there was smoke comming from under the hood and the smell of burnt plastic. After disconnecting the battery and checking it out, the wire from the A terminal on the generator to the GEN terminal on the regulator was burnt. Today I removed the cover on the regulator and looked at the points, they seemed fine. I replaced the wire cleaned the battery terminals and connected them. The wire was heating up again, so I disconnected the battery. This a short wire, I found no evidence of it shorting out anywhere. Has my regulator or generator gone bad?
