Super A Radiator
Rodger: The radiators are the same up to serial number 336711. After that that Super A radiators were pressurized. Those pressurized radiators are physically the same size and will still fit, whether you should use one, I can't answer that.
At serial number 356001 there was another change to a physically larger radiator, it will not fit pre 356001 tractors.
There is another matter you have to watch if buying a new radiator for a thermosyphon cooling tractor, make sure you get the right core for thermosyphon. If you can't get a thermosyphon core, you'll have to add a water pump. I guess this could also apply to a used radiator. Thermosyphon cored radiators have been increasingly harder to find in the past decade.
