hay JIMB2 . also any one have a manual for 354
Anonymous-0
i can not find any thing about the clutch adjustments.. also any one have a manual for 354
desiel. will pay for a copy
If you search the archives for 434 or 444 clutch about a month or more ago someone posted the specs on adjusting the dual stage clutch. Adjusting the fingers on pressure plate is done thru the inspection hole in the bell housing.
Hi Steven, I only have the Operator's Manual for B414 and it only shows how to adjust the free play of the clutch pedal.
Below from is from Archives:
Hi Jacques adjusts the three bolts to .090 of play and 3/4 to 1 inch of play for the clutch pedal. I worked 11 years for a seller Case-IH. Bernard le mechanic Rimouski Quebec
JimB
