Farmall super C tires and rims
Dustin hartmann
12-06-2007 11:43:10
I am restoring a Farmall super C for my 4H project and am looking for 11.2-36 back tires new or used and also 10inch rims mew or used. Does anyone have some or know a discount rim and tire place close to maryland
Thanks Dustin
Rusty Jordan
12-07-2007 18:04:07
 Re: Farmall super C tires and rims in reply to Dustin hartmann, 12-06-2007 11:43:10
Hi Dustin, I was wondering why you want to put 11.2 X 36 tires on your tractor. You noted that you are restoring your Super C for a 4H project. The original tire size for your tractor was 9” X 36”. So perhaps if you are restoring your SC to original, the 9” would be the way to go. But if you really “use” this tractor, you can go with a larger size. I also have a Super C and I have 12.4 tires on it. But mine is a working tractor. The bigger tires make a big difference when plowing. So, good luck with your Super C and I hope you post some pictures when you’re done. Rusty
P.S. Leon is right M&M in NJ is a good source for anything Farmall.
leon
12-07-2007 05:43:47
Try M&M Repair, New Egypt, NJ. 609-758-1936
504-2
12-06-2007 19:48:48
Dustin, I bought a new rim with out the mounting flanges, I took the old ones off and welded them on the new rims. It was less less than $50.00. OTR Quincy IL
Dustin hartmann
12-06-2007 15:46:39
shipping might be a llitle much from illnois Thanks any way Dustin
Brian Schmidt
12-06-2007 14:52:40
I have a pair of 11.2X36 on Super C rims. Real good to new tread. $450. Illinois is pretty far away from Maryland though.
gene bender
12-06-2007 12:19:51
You should be able to find new TITAN 11.2X36 for around 225 if you want new ones. Prices do vary you need to shop around as there are good prices to be found
MJD
12-07-2007 03:49:30
 Re: Farmall super C tires and rims in reply to gene bender, 12-06-2007 12:19:51
Do you have a phone number for the TITAN brand tires for a Super C ?
Thanks !!
