Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
IH D282 engine
David Carter
04-24-2006 12:31:50
Does anyone have any info on torque sequence for International D282? A used manual for rebuilding engine also any info on which engines may bolt up to the 282 flywheel & bell housing? Looks like it's a converted gas engine to diesel? Came out of 1959 Hough Wheel loader.
P Backus
04-25-2006 06:40:03
 Re: IH D282 engine in reply to David Carter, 04-24-2006 12:31:50
I assume you mean head bolt torque sequence. Here it is for a D282, with the front being to the left.
13 7 5 1 3 9 11
12 10 4 2 6 8 14
I would be very surprised if the IH engineers redesigned a gas engine into a diesel. It doesn"t have any specs close to a gasser that I know of. There were a ton of them made, too.
Paul
Aces
04-25-2006 10:36:18
 Re: IH D282 engine in reply to P Backus, 04-25-2006 06:40:03
Paul The D282 is just that a gas running on diesel. It the first D282's the crank was same part number' all had samw bearings same block just bored for the bigger pistons for the D282 and yes they did well.
P Backus
04-25-2006 13:03:30
 Re: IH D282 engine in reply to Aces, 04-25-2006 10:36:18
I was looking in my I&T manual and yes, it seems to be similar to the C263 engine in specs. And, as promised, I am surprised! Usually when that sort of thing is done, they end up with problems, but the D282 is a good motor.
Huh, I learned something today!
Paul
El Toro
04-24-2006 12:39:21
I think the 358D engine will fit and they were used in some Hough loaders. Hal
Copyright © 1997-2015 Yesterday's Tractor Co.
