Farmall C waterpump
Can be done, yes. Pump, a different generator brace and a different belt. It will take some improvising to fit it with a thermostat, though.
If you think you need a thermostat you have to change the housing that fastens to the head it will be larger than the outlet os your radiatoe i wouldnt worry about a thermostat. Those engines will run without a thermostat.
I think the fan blades are a little narrower on a water pump equipped engine. There isn't much clearance between the fan and the pump shaft.
