Hi all and reponce to Don Doyle I had done some trouble shooting today. Pulled rockers and retorch head replace 1 stripped stud. reset valves and Filled tractor with water just before I started it. Full radiator ran for 1 hrs never missed a beat.
Did see some water drops comming out of exhaust.
After I shut it down steam from exhaust so I drained radiator brought #3 to TDC and blow air in to dry out. Pulled exhaust manifold Put water back in radiator with #3 TDC and valves closed
No water in cylinder but water running out of #3 exhaust port so I would think head has a crack in it. Can a valve guide leak water? Thanks for any ideas you may have. oldiron29
