Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
350 farmall hydraulic fluid change
picasso
05-19-2004 19:52:44
I need to drain and change the hydraulic fluid in my 350 row crop. I understand that there are several drain plugs that I have to remove, is this true? how many and where are they all? I have an all hydraulic loader on it so I'll have to drain that to, what is the best way to flush the system? how much hyraulic fluid will i need and will hy-tran work or do I need a specific hydraulic fluid for a tractor this old? any help would be appreciated. thanks in advance..
Aces
05-20-2004 04:59:29
 Re: 350 farmall hydraulic fluid change in reply to picasso, 05-19-2004 19:52:44
Picasso sounds to me as though you are thinking the tranmission and hydraulic are all one on the 350. They are not. They both take Hytran, but the hydraulic has a resevor just below the hydraulic valves on top of the rear end cover. There is a creen filter on the right hand side with 4 1/4" screws holding it in place, fill plug just above it, if I remember right a drain plug on the left side, 1/4" pipe plug. The TA and rear end have three drain plugs, one under TA, one at front of rear end, one to the back of rear end under bull gear.
Copyright © 1997-2015 Yesterday's Tractor Co.
