Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Firing order for farmall C
Scotty
10-11-2003 14:41:11
I have a farmall C with a 4 cyl. mag. type distributor .Can anyone tell me the firing order for this tractor ? And if possible does anyone know how to time the mag . to the dist. ? Thank you for any help Scotty
MD Wa.
10-11-2003 19:53:33
 Re: Firing order for farmall C in reply to Scotty, 10-11-2003 14:41:11
Scotty. The mag. on that eng. turns clockwise. Use the hand crank to turn the eng. you more control coming up on top dead center. Pull #1 plug to make sure you are on compression. LOL Morgan
Scotty
10-12-2003 02:45:18
 Re: Re: Firing order for farmall C in reply to MD Wa., 10-11-2003 19:53:33
Thanks LOL Morgan, I will roll the motor around to compression stroke on # 1 cyl point the rotor at # 1 on the cap , wire the cap 1342 clockwise and give that a try.....thanks, Scotty
Tractor dan
10-11-2003 16:34:24
1342
Scotty
10-11-2003 16:53:32
 Re: Re: Firing order for farmall C in reply to Tractor dan, 10-11-2003 16:34:24
Thanks Dan, they are the numbers I used but it would back fire through the exhaust, I was hoping they were the right numbers but didn't know for sure , I think I have a magneto timing problem. Know anything about magneto's ? Thanks Scotty
Dave_Id
10-11-2003 15:14:56
The firing order is cast into the block, I believe the right side by the spark plugs
Scotty
10-11-2003 16:46:08
 Re: Re: Firing order for farmall C in reply to Dave_Id, 10-11-2003 15:14:56
Thanks Dave, I'll check the block for the numbers. Know anything about timing a magneto?
kjm
10-11-2003 18:38:53
 Re: Re: Re: Firing order for farmall C in reply to Scotty, 10-11-2003 16:46:08
Did you wire it clock wise?
Scotty
10-11-2003 19:16:58
 Re: Re: Re: Re: Firing order for farmall C in reply to kjm, 10-11-2003 18:38:53
I wired it which ever way the rotor turns when the starter cranks the motor but I just bumped the starter motor , when I did I could have been seeing kick back from compression . Maybe I better find out which way for sure the rotor turns .... Thanks, Scotty
