$$$$$$$$$ Oil Pump $$$$$$$$$$$
Ray
09-21-1999 08:45:13
I'm getting together the overhaul kit for my Super C and was priceing a oil pump and boy did I get a suprise. He has one in stock for $350.00 and if he was to order one it would almost $450.00. Does these prices sound right.
mike
08-22-2001 10:17:47
 Re: $$$$$$$$$ Oil Pump $$$$$$$$$$$ in reply to Ray, 09-21-1999 08:45:13
you can give that old oil pump a new lease on life if the gears and shaft are in ok condition. try taking the aluminum cover off the pump, place a sheet of emery cloth on a piece of window pane on the wokkbench. put the aluminum cover grooved side down and work it on the emerycloth till youve worked all the grooves out of the plate. cut a new gasket and reassemble it. it will have taken all the slop out of the gear surface thereby creating more oil pressure i did it on my 240 and my oil pressure is as good as when it was new.
