#1 cylinder
Wayne H. Thomps
01-28-2003 11:22:17
I thought #1 cylinder was the one closest to the radiator. A replacement head I installed has #4 on a raised portion of the head by the cylinder closest to the radiator. Am I wrong?
I don't have a cover plate for the clutch housing. I cannot find any indication of TDC on the starter ring. Is it on the front or rear side?
CNKS
01-28-2003 13:05:05
 Re: #1 cylinder in reply to Wayne H. Thompson, 01-28-2003 11:22:17
#1 is closest to the radiator. You did not say what your tractor is. If it is a C113/123 for an A,B,C,SA,SC etc the TDC mark is on the flywheel as you look thru the access hole. It is there and it is very hard to find. Turn the flywheel with a long screwdriver.
