Farmall F-20 torque specs
Ben Haag
12-22-2002 23:18:50
I need the torque specs for the head, and rod caps... Is the valve assembly torques to?? if so whats that to..??? thanx
Big E
12-23-2002 13:32:02
 Re: Farmall F-20 torque specs in reply to Ben Haag, 12-22-2002 23:18:50
I just torqued my F-20 head this past fall and the book i have says 85 psi. Take the time to do a hot and a cold torque, because I had some water leakage into the cylinder and if i had not caught it, that would have been bad news had it froze. I retorqued it hot and it sealed right up. Becareful not to break off a bolt though, they are no fun getting out, believe me. As far as the rocker arms, I beleive my book said 25, but I just got mine ratchet tight
Karl O
12-23-2002 11:07:16
They didn't have torque wrenches handy back then, so no specs were provided. I generally either consult one of the bolt size vs torque specs, or just pick a similar IHC engine. The M, for example. Rod bolt torque was 53 ft-lbs, head bolts were 110 ft-lbs.
