Farmall H tires
I believe the rims are original. What is the widest 38" tire I can install without any major problems? I am having trouble finding used 11.2s and don't really need new ones.
I'm using 12.4's, and have heard or people using 13.8's. I've seen 13.8 and they look a little too wide IMO.
(quoted from post at 09:28:23 03/28/09) I believe the rims are original. What is the widest 38" tire I can install without any major problems? I am having trouble finding used 11.2s and don't really need new ones.
First, I suggest you determine your rim width. Both 9" and 10" are common to H's. If 9", then 11.2's are ideal; if 10", then 12.4's are ideal. If someone has put 11" M rims on it, then 13.6's are ideal. I'm not saying you cannot put on larger tires than those - just saying what is ideal for those width rims.
mike
