radiator leaks/fixes
Jesse
I was curious has anyone ever used Dike in a radiator? I have a can and was wondering if I should use it on a Cub. Course it might be better to just replace the radiator, but I thought I would ask about the Dike first, as that is ALOT cheaper. I was just unsure about how it might affect the block, if at all.
My gut take on it is that for that type of fix to work at all it takes a pressurized cooling system to force the little flakes into any holes to plug them.
And what happens to all the little flakes that don't plug holes? They settle somewhere.
If your leak is small enough that you think that your sealant potion would work, it ought to be a pretty simple fix for any radiator shop.
