'44 H
Mitch
05-11-2002 06:08:01
I installed a new coil spring in my seat yesterday. But the small/lower end of the spring doesn't sit flat over the knob on the rear seat support. But I couldn't get it to come out either and seems alright. Has anyone experienced this also? And do you think spring will settle better in place after some use?
Zonie
05-12-2002 21:13:26
 Re: '44 H in reply to Mitch, 05-11-2002 06:08:01
the spring on my H is original IH spring and mine doesn't sit flat either until I sit on the seat. It has never come loose.
howard
05-11-2002 06:41:30
did you buy your spring from IH ?
The Red. Hmmmmm
05-11-2002 06:31:49
That's odd. I just looked at a couple of original H seat springs I have out in the garage. They are ground down flat on the small end. You might try rotating the spring to see if that bottom will fit better.
