Super MD (update
Andrew Z
I worked on the Super MD today, i checked the fuel pressure gauge and turns out the gauge doesn't work well, put a 0-75 gauge on and it has 60+ pounds of pressure so i think im good there. I cracked the injectors and all of them have fuel coming out of them. I took the front cover off the timing gear and it was about 2 notches out from 0 on the gauge after trying it a half dozen times it seems to run better with it set to the 4th notch to the left of zero (count-clock wise facing the gear) The only thing that gets me is that it will idle down and stay there for a about a min and then it will stall out like i cut it out. Anything above 800 rpms im guess it runs great. Any ideas why it wont stay idling?
Thanks
Andrew
it is of the rhythmic pulse it seems to shoot out of the bleeder pretty good i would say a steady stream of at least 5 inches or so.
Andrew
