How to test an amp gauge
Paul Shuler
08-15-2001 22:00:30
My super C has an amp gauge from a much newer tractor. I was in a salvage yard yesterday and saw and IH amp gauge that looked like new on an old Super C. I got it for $5. Is there a way I can test this gauge to see if it still funtions correctly before I install it. I have a good voltmeter that when I put it on ohm's it had continuity but not sure if that tells me anything about the condition of the gauge or not. Sorry if this is a dumb question. Electronics is not my strong point..... ..I'm not sure what my strong point might be?
Bob M
08-16-2001 07:03:52
 Re: how to test an amp gauge in reply to Paul Shuler, 08-15-2001 22:00:30
Hi Paul! Testing your ammeter is simple. Just take a working 12 volt lamp (a headlamp or 1157 stop/turn bulb) and wire a simple series circuit:
Battery to one ammeter terminal; then other ammeter term to a lamp term; then other lamp term to battery -. When the lamp lights the ammeter will indicate the lamp current draw if the ammeter is working. (Disregard whether the ammeter reads charge or discharge - that will depend on which ammeter terminal you select.)
Bob
Paul Shuler
08-16-2001 09:36:28
 Re: Re: how to test an amp gauge in reply to Bob M, 08-16-2001 07:03:52
Thanks guys for an easy test. Will try it out.
Ralph
08-16-2001 07:03:51
Paul: Sure. Get a light bulb and put it in series with the amp gauge and put all(in series) across the battery. Use the tractors light bulb(6 or 12volt) This will show a discharge. Flip the amp meter around and it'll show a "charge". This a quicky test. One could use a variable power source and test at all volt\amp settings if ya wanna get serious? Not too much to go wrong with an amp meter so a quick test should do it for the charge\discharge movement. ralph
Phil Auten (Tx)
08-16-2001 07:01:00
Paul,
The gauge should have continuity because there is a shunt resistor, about 1/10 ohm, across the meter movement. The Ammeter is really just a voltmeter connected across this internal shunt resistor. Current through the resistor causes a voltage to be dropped across the resistor which is proportional to the current through it. That is the basic description of how the Ammeter works. The voltage is polarized, depending on the direction of current flow, thus the charge and discharge sides of the meter face.
The easiest way to check it is to install it and see if it shows a reading. Shouldn't be too hard to do, just be sure to observe polarity on the meter connections.
Phil
