884 international hydraulic problems
$pipeliner$
New User
I recently bought a 884 international and the steering was hanging up and whining so changed the pump. When I changed the pump when u let the powerlift down it would load up. So I changed the whole MCV Valve and pump worked ok until I put a loader on it. Up and down and tilt down on the loader worked fine but the up tilt tried to work thru the powerlift. If you had any weight on the loader and and tried to tilt up the tilt would go down fast. Well the hydraulics completly wuit so I put another MCV Valve and pump on. Now the loader is working with the powerlift again in the up position and the tilt. Can someone please help me here.
