Model 72 Grader Blade
smcIND
I am looking for a part for mounting the blade on a mid mount location. Does anyone know where I can find the part I have pictured
or the specs on it so I can make one. thanks
Recently I sent a tracing of that part to a man in WI who forwarded it to a man in CO. The CO man was to make a better drawing and post it for others to use. Maybe he will see your posting. As I recall he tried by trial and error and was 4 inches off in one dimension.
If all else fails, take the measurement of a known part that you have, which appears in that drawing. Measure that same part in the drawing. Now you have a scale that is "close enough" to figure out the dimensions of the part you need to fabricate.
Looks like you need 2 of them one for each side I have 2 of them send me your address you can have them for free just send me a check for shipping after you get them you can call text or email me 814-730-3076 thanks chad
(quoted from post at 13:38:06 01/19/19) Looks like you need 2 of them one for each side I have 2 of them send me your address you can have them for free just send me a check for shipping after you get them you can call text or email me 814-730-3076 thanks chad
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto10062.jpg">
Wow, that is very generous! I wish you would have seen my earlier post.lol :D I called the salvage yards I know of and no luck.
when I get them I will make a drawing and measurements so I will have them. I might just send you one of the two and make another one. Then you will have one for a pattern.
Thanks
(quoted from post at 20:43:03 01/20/19) when I get them I will make a drawing and measurements so I will have them. I might just send you one of the two and make another one. Then you will have one for a pattern.
Thanks
I really appreciate the offer, but I have already made a bracket for my plow that works well.
Thanks,
Dan
