Farmall MD parts
Put a wanted add in the classifieds section on this site.I am willing this site has MD starter also a starter for 400-450-560 three bolt diesel starter will work as they take the same ring gear.460 gas or diesel will not work including 560 gas models ring gears are different.As for hood if you can't find one at a salvage yard you may have to cut holes is m gas hood to make it work.Scott
Yes guys I forgot you have to add filler strip to make a gas hood work.No it does not look right but it can be made to work.My memory bank is slipping.Scott
A farmall m and super m gas use the same hood length. The farmall md, super md, super mta diesel and super mta gas all use the same length hood.
