super c main bearings
dewy
had some home made square washers under main bolts ,,bent up for backing out precaution...is that necessary under the main bolts..an if so i will use some round ones these looked scary,,like to close to moving parts....should of took pics but was moving to fast trying to tear down this motor....thanks dewy
i would just leave out those square tabs it came with as they usually get damaged too much from reuse. go with blue locktite instead. i would not use washers, flat or locks.
