I've posted a couple times on this. Replumbing hydraulic hoses. My Super had what I would call old tree valve mounted just to the right of bell housing. I've done away with it and planned to install valves back near seat with hoses for auxiliary. I had planned to run loop from pump to reservoir. Then tap my pressure line to my valve from left rear port off reservoir. Put my return line into fill tube. I thought that's what I had read on here in the past.
I mentioned that in a post and someone suggested tapping the two existing lines instead. Another post Barnyard (hope your reading this) made sense in saying that wouldn't work. Now I have looked over my old lines which are no longer on the tractor. Both had T fittings in them that supplied that old valve. I'd say it had been that way for 20-30 years before I got the tractor.
So now I'm confused. How should I do this? Can someone submit diagram or picture of such.
Thanks guys. I could put it back with Ts like it was but now wonder if that is right.
