806 hydraulics
Did this happen all of a sudden or is the tractor new to you? If you have had some experience with
the tractor does it load the engine and squeal or buzz when you move the valve to raise the
implement? If so then you may have a problem with a quick coupler tips that Fast refers to. Un-
couple the remote cylinder hoses and plug them into the opposite connectors and see if this
helps. Sometimes they wear and won?t release properly. There are tip style and ball style
sometimes mixing one and the other causes problems. Good luck and Welcome to YT!
I don't understand, the tips are operational? I have owned the tractor about a year. Has a loader on it. That's it's primary function. This is the first time I've hooked an implement to it. No squealing or whining. Power steering functions normally.
My point was sometimes a tip, will malfunction, even though it look's good,and feels like it in the receptacle properly, and just have to change one, by trial and error !!
Ahh....Ok. The hose that goes to the cylinder is brand new with new pioneer fittings. I've tried moving to the upper and lower remotes. I'm going to have to look closer at the fittings on the tractor, thank-you.
